Outdoor lighting - no waterproof junction boxes | Page 2 | on ElectriciansForums
Discuss Outdoor lighting - no waterproof junction boxes in the UK Electrical Forum area at ElectriciansForums.net
London
Hi, could someone please let me know whether the attached pictures is safe for step lighting?
From what I can see, the contractor has cut away the insulation from the cabling that was suplied by the manufacturer and used standard junction boxes wrapped with electrical tape.
This doesn't feel sufficient to me so just wanted some more advice.
Thanks in advance
[ElectriciansForums.net] Outdoor lighting - no waterproof junction boxes
A hole in a wall is not really a joint box. The gel & brick will eventually part company. What's on the other side of that taped up connector? Details of luminaire?
Knightsbridge LEDM06 - link below.
0.6W LED Mini Ground Light White with 3 Interchangeable Heads | City Electrical Factors - http://www.cef.co.uk/catalogue/products/3871327-0-6w-led-mini-ground-light-white-c-w-3-interchangable-heads
No transformer, fed straight from mains.
Otherside of the junction box is the cable coming from the brickwork which is now not accessible.
Agree with above - stick a waterproof plug and socket coupler on. Damp is bound to get into those joints at some point.
Are your sure that is the exact fitting? The manufacturers data sheet suggests it must be earthed, although it confuses things by saying its Class III and 230V?
The luminaire in your picture suggests its double insulated Class II and doesn't require earthing, your picture suggests the lead doesn't have an earth wire. This needs clarification?
That is a bit odd but it is the correct fitting. The installation sheet (attached) mentions that is does not need to be earthed so one of them is wrong.
Given I have not paid and I don't want the contractors messing around with the steps anymore what are my options?
Can I refuse to pay given its a workaround that will not stand the test if time?
I certainly wouldn't pay for a choc-block wrapped up in tape in an outdoors environment. Needs a waterproof joint or a waterproof plug/socket.
The data sheet says class II - no earth needed.
As to how to progress, I would get the installer back and say your not happy with the work. How you're (or they are) going to improve things might be problematic. Could you post a picture that shows the install a bit clearer?
I had a job a couple of months ago where I had to tidy up a mess left behind by a previous 'electrician'. He had installed some step lights in a simple manner and needless to say they stopped working after a few months. The holes were full of mud and insects, as on the other end of the hole the cable entry point was underneath a load of soil in a flower bed.
I used Wiska Shell Boxes to terminate the connections inside the hole. They are IPX8 rated so nothing can get inside them.
MJB112 - WISKA - make power smile Installation material - https://www.wiska.co.uk/products/pde/MJB112/mjb112.html
Good shout, but what are their dimensions? Just thinking of OP 'holes'.
I can't find any dimensions on them on line but they are pretty small as effectively they only have two Wago clamp type connectors inside. I haven't got any left to measure them either, as they are not cheap about a fiver each but they are a really good bit of kit.
You could use two singles with just a single Wago connector in each, so one for each wire if a two way won't fit.
I think the light is the knightsbridge LEDM06 which comes with a 2mtr 0.75mm cable, they are rated IP65 but i suspect that is only valid when the outer sheath is sealed to an IP65 enclosure so that no water can ingress down the sheath?
The light is now bin fodder as the cable is most likely too short to make a suitable seal between an IP65 enclosure and the outer sheath of the cable, based on the very poor standard of work i would also suspect that the cable feeding the lights from your house isnt suitable protected in the ground either.
Reply to Outdoor lighting - no waterproof junction boxes in the UK Electrical Forum area at ElectriciansForums.net
I've made the required tweaks on the junction box with a 4mm hole bottom, upturned wagos and reduced the exposed copper. I did originally install...
There is no homework, and I'll never see these photo again.
