Guest viewing limit reached
I have 2 double outdoor led lights on a dimmer. Over xmas the lights flickered then went out. I thought one of the wires came loose, i checked all connections, all ok. Will a faulty dimmer cause this? or is the power board likely to be the problem? A bit hard to get a sparky at this time of year. thanks in advance
It is unlikely that a dimmer is suitable for your outside lights. (Unless they were designed specifically to work together)
try a normal switch.
Thanks James, the switch is inside, with the outdoor lights under cover on the patio. I managed to fix the problem by bypassing the dimmer. For some reason the dimmer was wired to be hot even when the light was switched off.
there must be somthing wrong with LED chip or driver . if the driver is external, you can buy a new one and change it. if not. May need to buy a new light
Australia
Outdoor lights not working
Australia
DIY needs troubleshooter,
Cathy-Tienli lux,
