Guest viewing is limited
Any ip66 gland is fine. 20CW is just the manufacturers code for it.
Actually, make sure your glands are for SWA, not just a compression gland with a rubber ring that closes up when tightened
This is the kit I purchased (from Screwfix - see link below.) I have assumed that this will provide the appropriate fixing. Am I correct?
Yeah, that’s exactly the same as a 20CW.
The armour is gripped between the two brass parts for earthing purposes, then the compression part is tightened around the outer sheath of the cable to create a waterproof seal.
Then the shroud is slipped over the top of all of it.
Edinburgh
United Kingdom
Outdoor socket, regs, spur.
DIY Electrical Advice
EdinburghEd,
littlespark,
