Outdoor socket | on ElectriciansForums
Discuss Outdoor socket in the DIY Electrical Advice area at ElectriciansForums.net
UK
I am going to put a socket into some brickwork surrounding a BBQ area. Now all the external sockets I have seen are all surface ones about 3 inches deep this sort of skt.
[ElectriciansForums.net] Outdoor socket
Now I thought of using the type of socket one gets on the outside wall of a caravan like this which will sit more flush to the brickwork.
Any other options/opinions gratefully received.
Not got a link by any chance. I have searched youtube and cannot find anything re flush sockets or a guy called Keiran.
@westward10 has posted the link.
Don’t take the installation seriously whatever you do. Probably one of the worst botches I’ve ever seen in my life. Well worth a watch for a laugh though.
Best advice I can give you is pop to a local wholesaler, explain what your trying to do and they will be able to show you various designs which look aesthetically pleasing. ?
Also just bear in mind that installing a outdoor socket is best left to a qualified electrician as it will need additional protection and testing and inspecting correctly.
British General IP66 13A 2-Gang DP Weatherproof Outdoor Switched Socket - https://www.screwfix.com/p/british-general-ip66-13a-2-gang-dp-weatherproof-outdoor-switched-socket/67928
Our electrician fitted these. I think I messed up his tea order one day and this is how he got his own back. They are very difficult to un-clip and clip-shut - but as a result are always very well sealed closed hence IP66. I have to kick them open and closed - perhaps my age though. Actually I am content - they will stand the test of time. But, if you want/need easy open and close be careful what you buy.
They are the big bulky jobs I do not want in this case.
Having seen the video methinks I will stick with the caravan socket.
Isn't that caravan socket only waterproof when fixed to a flat panel though? Not sure how it would fair on a brick wall.
Well the caravan wall is flat agreed but if you have ever taken one off there is usually about half a tube of sealant stuffed behind. I think a caravan socket sealed to the brickwork will be fine especially as it is not exposed to direct rain.
Reply to Outdoor socket in the DIY Electrical Advice area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
    • Friendly
Thanks so much for sharing this with us! I’ll definitely take a look, it seems like there are a lot of useful and interesting products. The idea...
Generally it would depend on the circumstances whether the armour is earthed both ends or not, and not just dependent on whether it's 2 or 3 core...
