outdoor trunking | Page 2 | on ElectriciansForums
Guest viewing is limited
Discuss outdoor trunking in the UK Electrical Forum area at ElectriciansForums.net
B
bobbyr
Hello All
Is there any type of square trunking that can be used outdoor for domestic purposes. The customer doesn't want to paint over cable or galvanised trunking and I need to run a 10mm supply to an outer building. Any suggestions? cant go In the ground either as he has blocks on top of concrete.
thanks
I've had 2000m of white high UV resistant 20mm electrical conduit shipped into Afghanistan. All accredited (CE and UL) as fit-for-purpose for this harsh environment ! -20 to +60, Uv rated to Level 10 .... but it is more expensive than standard conduit, but it is out there to buy.
Example from Google:
Outdoor Electrical Uv Resistant Pvc Conduit - Buy Uv Resistant Pvc Conduit,Ourdoor Pvc Conduit,Electrical Pvc Conduit Product on Alibaba.com
We live and learn... lol!!
Its always interesting this UV stuff and the effect it has. We all know best practise etc .. dictates that outside we should be using UV tolerant but how many times have you seen grey T&E, white multicore or white trunking/conduit that's been outside for donkeys. Maybe a bit of weathering on it but other than that functioning well!!
Maybe more of an issue in sunnier climes with an aggressive sun (plus more of it) than the UK, plus clearly dependent on how well its hid from the sun. I know my mothers house had all the external lights run in a white multicore, clipped to the brickwork some 30yrs ago by my Dad and they're still going to this day ......
I have seen plenty of T+E and white conduit that has been outside for decades and still functioning fine. I have also seen my fair share of brittle, cracked, examples of both from the effects of UV and weathering that is nowhere near suitable for continued use.
Depends which way the wind is blowing I suppose....
If the OP was talking about using mini trunking, can you imagine what it would look like even when new for gods sake!! lol!!
The general type of plastic used for white conduit etc, will become brittle in the presence of UV. Conduit that has been in place a number of years, will if tapped or inadvertently hit, break up into little bits around the area it struck. From then on, it's a steep downward trend of decay to a point where just touching it will cause it to disintegrate further ... lol!!
Reply to outdoor trunking in the UK Electrical Forum area at ElectriciansForums.net
Recommended Sponsor News
Hi everyone,
