outdoors christmas lights | on ElectriciansForums
Discuss outdoors christmas lights in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Y
youngpadawan
Hi guys, been asked to hang a bunch of 'holiday' lighting, both to a tree and hanging over the road. These lights all plug into ip rated outside plug sockets, and have never had a pat test (or any other sort of test). Is this correct? Or is it exempt for being external? Seems a bit irish to me!
If you are just plugging them in then they are not covered by BS7671, however you should ensure that they are safe to use, which could be done through PAT testing, or perhaps just a visual inspection depending on voltage.
Hanging over the road sounds somewhat dicey as you may be affecting the public highway.
Reply to outdoors christmas lights in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Or just save all the agro and get a proper sparks round for 45 minutes to test the supply cable and re-fit the socket 'properly'
Ok I’ll try this when I’m down
