Outlet and switch question | on ElectriciansForums
Discuss Outlet and switch question in the UK Electrical Forum area at ElectriciansForums.net
1. I took the cover off the outlet and turned the breaker off which turned off my tester and as an added measure I use my non contact test and one of the 4 wires is still live. Is that bad and if so what could cause it?
2. I have a switch that doesn't have a ground or neutral just 2 wires, I replaced the light fixtures already which had a ground wire but they never attached it, does that mean the ground wire wasn't hooked up and how hard is it for an electrician to add a ground and neutral at the switch. I think I can access the wiring to the switch from the basement but does it also have to be run to the fixture?
Never use a non contact tester - completely unreliable, usea two wire voltage tester
[ElectriciansForums.net] Outlet and switch question
Reply to Outlet and switch question in the UK Electrical Forum area at ElectriciansForums.net
That worked!!! Thanks again for all the help and responding so quickly. Really appreciate it!!!
