Outside EM lights control | Page 2 | on ElectriciansForums
Discuss Outside EM lights control in the UK Electrical Forum area at ElectriciansForums.net
London
Hi can anyone do an outside lights wiring diagram for me please,
  • Outside EM maintained lights
  • All be on 1 circuit
  • EM key switch for EM lights function
  • Contactor
  • Photocell for EM standard use
  • Override for EM standard use
Feed (Line), Neutral earth to Contactor. Feed from top of contactor to Photocell L/IN, loop a feed to the Key switch. Key switch line to Emergency fittings. L/out from photocell to A1 of the contactor coil. A2 Neutral, Switchline, Neutral, Earth out of the contactor to your lights.
Hard to type it... If I’m free I’ll draw what I would do.
Thanks I’ll do a drawing later, appreciate your help think I’ve got the idea
[automerge]1569577387[/automerge]
Break it down into seperate componants. Neutral and earth are easy, just connect to everything that needs it.
You need to take a live to the permenant live terminal, and this needs to be interupted by the test keyswitch.
You also need to take a live to the switched live, and this needs to be interupted by the photo cell.
You also want to bypass the photocell with a switch, so wire a switch across the lives on the photocell.
Or, insert a switch between the photocel and the light, take com to the switched live, L1 from the photocel and L2 from the live feed, and the switch will switch between them
Appreciate that I’ll do a drawing later and see if it’s all good thanks for your time
Sorry, missed the contactor bit, feed the coil of that instead of the light, and then use the switched terminals of the contactor to drive the lights. You will need 2 if you need a contacto
Sorry i missed the contactor bit but you would just feed the contactor coil instead of the swich live as mentioned above. And then take the switched contactor output to the switched live on the lights.
Hi guys im trying to do a drawing, but I’m confused plus only have black pen...
[automerge]1569696880[/automerge]
  • [ElectriciansForums.net] Outside EM lights control
Reply to Outside EM lights control in the UK Electrical Forum area at ElectriciansForums.net
A suitable contactor can be used for safe isolation, but to be suitable it must be marked with the specific symbol for isolation and would have to...
Thank you so much for your help with this light work perfect now thank you again much appreciated
