G
Grant Naylor
Hi the client has a 6A light circuit already installed to supply an outside light attached to the wall. However, the CCU is 2007 and the circuit does not have and RCD protection. A fews questions sprung to mind.
1) The light fitting would be attached to the house and fed from the existing circuit/wiring directly into the accessory and so under Part P is non-notifable. An MEIWC is needed.
2) Even though there is no light accessory, the circuit supplying the light is already there and would be unchanged so again non-notifable. No need to add RCD protection as no change to the circuit.
3) If a 6A Type B RCBO was fitted at the clients request, this would be a change to the circuit and an EIC would be needed.
Any feedback greatly appreciated.
