outside lighting cable | Page 3 | on ElectriciansForums
Discuss outside lighting cable in the UK Electrical Forum area at ElectriciansForums.net
after some advice pls
have a outside work area ( open ended but covered from rain and sunlight ) customer requires two 36w IP65 flossy fittings and switch installing. Planning to fuse off existing outside socket with a 3amp fused connection unit. I cant seem to find any 1mm 3 core weather resistant rubber flex locally, but 0.75mm 3 core is readily available. Can anyone see a problem with using the 0.75mm as calculations show volt drop and ZS all ok. Fixed load of only 100watts max so current well below the rated 6amps. I know that minimum lighting circuit cable should be 1mm for fixed wiring but as this has a 3amp fuse protection would it still be a breach. have a niggling feeling this is still classed as fixed wiring.
many thanks.
Reply to outside lighting cable in the UK Electrical Forum area at ElectriciansForums.net
😄 It wasn't the worst I seen over the weekend. Took the kids to Cumbria zoo whilst over there, and the toilets by the giraffes just had twin...
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
5K
Recommended Sponsor News
Hi everyone,
