outside lighting controls | on ElectriciansForums
Discuss outside lighting controls in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
M
marty88
Hey guys, I've been tasked to connect 3x 250w floodlights controlled via a photocell and timeclock with contactor(all din rail mounted in an enclosure) iv already run 3 white fps to each flood and a 4 core fp back to the enclosure from the photocell, I understand I need a 5amp supply to my control circuit and one for my floods, connecting into and out of the time clock, it's just the contactor connections still baffle me! So anyone kind enough to explain this?
Reply to outside lighting controls in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi Richard, thanks for your comment. The relay is rated 12A peak. It's also worth noting that a relay contact will perform differently depending...
    • Winner
