P
peteelecs
I want to put up a couple of 60 watt lamps on wall by patio is it ok just to use 1mm2 twin and earth on its own or do I have to put it in conduit thought this might look too bulky Any advice appreciated
Discuss Outside lighting in the Talk Electrician area at ElectriciansForums.net
you can use T/E, but flex will look better and stand the weather better. 0.75mm would be adequate
Flex is only permitted if it is run through a FCU first. Flex is not meant to be used as a installation grade cable in the way that T+E is.[/QUOT
and the reg. is???
Reply to Outside lighting in the Talk Electrician area at ElectriciansForums.net
