Outside lighting | on ElectriciansForums
Discuss Outside lighting in the UK Electrical Forum area at ElectriciansForums.net
Scotland
Currently doing some work in an commercial unit. Customer wants basic 400w halogen floods to illuminate car park and sign etc. I'm not too keen due to the frequency I'll be back changing lamps. What would you guys recommend that would give a similar light output.
i replaced 8 500watt halogens with 4 150watt M/H and the client said there was a lot more light (and a hell of a reduction in running costs)
Don't think it'll be too long before these high wattage halogen lamps will be obsolete. So apart from the fairly frequent lamp changes that is bound to occur, he may not be able to purchase these 1000W lamps for too long!! MH is a far better alternative, better all round in fact!!
75W or 150W Quartz Metal Halide or High Pressure Sodium. Choose Metal Halide if colour rendition is important, Sodium is generally cheaper to maintain. Widely available in IP65 floodlight fittings. If you are going to be responsible for their maintenance over the long term, Thorn Areaflood Size 1 would be a good choice as all parts are available as spares.
Money no object LED floods might come down in price in a few years DONT buy cheap ones tho
IMO 150 or 70 halides depending on the area to be lit I try n steer company clients away from halogen due to frequent lamp changes reliability ect recently we fitted 6 no 2X28w floory floods crackin light from them and not that expensive
150 Metal Halides for me too, used four to light up an equestrian outdoor menage, work very well,and relatively cheap to run. The light is clean too whereas sodium looks a bit glum in my opinion.
Reply to Outside lighting in the UK Electrical Forum area at ElectriciansForums.net
Protection from what? What kind of problem with the inverter is going to be helped by having an RCD on the circuit?
davesparks
