OP
No doesn't show the new ones they did. but they put their cable 6 inch up on the wall where the glass isSo the pic doesn't show this.
Discuss Outside lights in the Talk Electrician area at ElectriciansForums.net
Don't know who designed the patio bit I did electrical design and bought the lights toowho designed it, and who supplied the lights? because it's a pants design. the lights should go on the brickwork with short flexes into ad, boxes fed by SWA.
I don't want to kick you in the teeth but it isn't the best design, I suspect you think the same or else you wouldn't be asking on here, sorry.Don't know who designed the patio bit I did electrical design and bought the lights too
Hi, I've put some under ground lights in a restaurant with outside seating. The lights are in the ground but there is a kirb all the way around then some shale then a wall. I have come from armoured cable into a weather proof box. into a light sensor. then into a galvonised t box. this first t box is in the shale along with the rest of the wiring. from the t box with stuffing gland which goes to a ground light with flex which is fixed to the ground light. then also from the t box to another t box with armoured and then continues in the same pattern. Each t box has gasket and lid and is also filled with electricians silicone giving it ip68 compliance. I know there is a hundred opions about other ways it can be done BUT is there anything wrong with this way as this is the way I was taught and I don't believe it goes against any regs ? reason being is some other company has gone in and told them they need it all ripping out as it wrong
Reply to Outside lights in the Talk Electrician area at ElectriciansForums.net
