M
matt12321
im looking for a little extra advice as i keep getting told different things.
what im looking at doing is putting up 3/4 outside security lights and was wondering, which way is the best to wire them so they will work as motion detection and be controlled off a light switch.
can you wire them like a normal lighting circuit taking a permanent live to fitting and looping through to the others and then dropping a switched live to a switch from one of the lights using 2core and earth?
cheers
cheers
