outside socket price | on ElectriciansForums
Discuss outside socket price in the Australia area at ElectriciansForums.net
mcm
Would you say 60 pound for a outside socket is fair.
is it simply a case of turning up and throwing a customers socket on th wall then yes if its a case of checking bonding, rcd protection providing ip rated socket and testing and certifying then no, dont sell yourself short.
Would you have to upgrade main bonding conductor if incorrect csa before out any minor works such as described above? What if installing a new final circuit? I know you would when renewing db and also earthing conductor if incorrect csa.
Reply to outside socket price in the Australia area at ElectriciansForums.net
Although it might appear that I am being elusive with the facts, the point is, only you know what your worth is per hour and how long it will...
    • Optimistic
Thanks for that guys I was more thinking about difference in potential between the tub and wet paving flags . The tub is plastic . But it’s the...
