oven and hob on same radial ? | on ElectriciansForums
Discuss oven and hob on same radial ? in the DIY Electrical Advice area at ElectriciansForums.net
R
robsnow
HI guys
may be the wrong forum, if it is apologies.
I have a new hob 7.2kw and oven 4kw , I have laid a new 10mm t&e under my floorboards before tiling my floor and had an electrician friend come to have a look at connecting to consumer unit and connecting up the appliances.
He's told me they can't both be connected to the 10mm cable from the fuse box however from what I read on the forums it seems this is the norm, is he right or do I need a different electrician ?
He has said that he can connect the hob to the 10mm and the oven to the downstairs ring however that makes no sense to me at all.
any advice ?
thanks in advance Rob
Total current without diversity of the two appliances is well within the current carrying capacity for a 10mm cable and a 4kw oven shouldn't be connected to the ring.
:grinningelf:OMG, they got tinternet in biddle now.:6:
HI guys
any advice ?
Based on the info you have given your electrician is giving you poor advice.....yes you do need another!
Take 10 mm into kitchen then in an accessible unit fit a 2way enclosure rcd at c.u then in this unit main switch then 32a hob and 16a oven
overcomplicating. just split the feed to 2 outlets.
Suggest you find another electrician!! The one you've got sounds faulty and needs a re-boot.
Absolutely nothing wrong at all with a 2 outlet radial circuit supplying 11kW (before diversity) on a 10mm cable.
You might like to look at your suggestion again, matey.
as above. 10mm to cooker isolator, then split to 2 outlets. each in 4mm or 6mm. or, if both appliances are together, a dual outlet plate. and sack the pillock.
What's wrong with my idea?
The 10 mm gos into kitchen then split it in a 2way enclosure
then supply's power for the two appliances
So then at the consumer unit supplying this cable. What mcb would everyone fit?
B32 would be fine! Though as a 10mm's been put there then might as well make it a B40 'just because'.
nothing wrong with it. just a bit overkill.
Reply to oven and hob on same radial ? in the DIY Electrical Advice area at ElectriciansForums.net
allowing for diversity a 32 amp supply will be fine for them both, but remember, the cable needs to be adequate to cope with a load on up to that...
I've put a 2 way unit inside kitchen cupboards before now if we were re-using the original cooker supply but the customer wanted 2 x 16A ovens. I...
