oven and hob on same radial ? | Page 2 | on ElectriciansForums
Discuss oven and hob on same radial ? in the DIY Electrical Advice area at ElectriciansForums.net
HI guys
may be the wrong forum, if it is apologies.
I have a new hob 7.2kw and oven 4kw , I have laid a new 10mm t&e under my floorboards before tiling my floor and had an electrician friend come to have a look at connecting to consumer unit and connecting up the appliances.
He's told me they can't both be connected to the 10mm cable from the fuse box however from what I read on the forums it seems this is the norm, is he right or do I need a different electrician ?
He has said that he can connect the hob to the 10mm and the oven to the downstairs ring however that makes no sense to me at all.
any advice ?
thanks in advance Rob
Me thinks you need to consult (and pay) a sparky who knows what he's doing.
Even if the spark has minimal experience...im not sure how he can possibly justify saying they can't be both split off a 10mm t+e ...
pretty obvious really. im guessing he doesn't know his cable calcs
I think the main problem with the original electricians advise is his suggestion that the 4kw oven can be run off the ring.That alone makes me wonder if he is actually an electrician.
Thanks very much for the helpful answers, have posted on rated people. The cable is there, I have a dual ccu and a 45a switch, any advise on how much I should be paying for these to be connected ?
first quote of ÂŁ200 seems very hefty.
cheers
cheers
Oh dear
There is another thread on this forum dedicated to those who want to make laughter
[ElectriciansForums.net] oven and hob on same radial ?
If possible try and get a friend or relative who can give word of mouth experience of a reputable spark
What's wrong with my idea?
The 10 mm gos into kitchen then split it in a 2way enclosure
then supply's power for the two appliances
You should be asking yourself, What's RIGHT with it!! Talk about overkill, for gods sake!!
I'd have no problem or hesitation at all about using a 6mm cable to supply both these loads, seeing as a 32A OCPD sitting on 6mm cable is good for 15 KW, so were already on overkill as far as the 10mm cable size that's installed.
Back to the OP. .....This so-called electrician friend of yours, sounds like an under qualified inexperienced DI that are now flooding the domestic industry. Find an electrician that's been in the trading as an electrician a good number of years, or by trusted recommendation from friends/relatives!!
Reply to oven and hob on same radial ? in the DIY Electrical Advice area at ElectriciansForums.net
allowing for diversity a 32 amp supply will be fine for them both, but remember, the cable needs to be adequate to cope with a load on up to that...
I've put a 2 way unit inside kitchen cupboards before now if we were re-using the original cooker supply but the customer wanted 2 x 16A ovens. I...
