Oven fan not starting | on ElectriciansForums
Discuss Oven fan not starting in the Australia area at ElectriciansForums.net
M
magicdaps10
When i press the button to start the fan it does not work.When i hold it down and keep my finger on it,it works but as sson as i release it stops.
The light switch works so i think the switch has gone.
How do i replace the switch?
Bare in mind i am a complete novice!
many thanks in advance.
Bets thing to do is look in your local rag paper and you should find in the back people that specialise in this kind of thing and normally they are cheap enough, ovens and washing machines aint worth getting into
Reply to Oven fan not starting in the Australia area at ElectriciansForums.net
Elkay 2235A-1 Energysense White 3 Wire Touch Timer 16A 240V. This is a touch timer (you don't need that bit) which also can be activated by a...
yeah, think this will be the best way around it for me, thanks, having thought about it, if the country is as short of sparkys as peope make it...
