Discuss Oven with 13a plug top in the UK Electrical Forum area at ElectriciansForums.net
Why replace the cooker switch?Replace the cooker switch above the worktop with a 13a switch fused spur, and then the cooker outlet under the worktop with a single socket.
No downgrading of the MCB required.
wrong.... 2 x 13A fuses in series. which one blows? ipf post #16 says all.Replace the cooker switch above the worktop with a 13a switch fused spur, and then the cooker outlet under the worktop with a single socket.
Presuming it's wired in 6.0mm cable, just replace the outlet point with a socket controlled via the cooker unit.
I wouldn't fancy 6mm in and out of a fcu, either.
Reply to Oven with 13a plug top in the UK Electrical Forum area at ElectriciansForums.net
