Hello, anyone know why an overhead crane would cut out. It only cuts out when it gets to a certain point in the building. I have IR,continuity test on from control buttons to main panel. Tested windings of the motor all ok. Checked the busbar channel to ensure connectors have not worn down. 7 contactors, 4 were replaced around 2015 i am led to believe, 3 bigger contactors are quite old. Couldnt tell you how old lol. None of the breakers trip and the controls pull in the contactors but nothing happens. No drawings to go by as the manual is from late 70's.
