La Poste
Greetings.
I am helping to re-wire a bungalow that has an earth rod.
The supply cable is overhead, it's the same for the whole street.
I took a walk up the road and noticed all the overhead cables converged on one single pole.
On the pole was written PME and three cables ran down the pole into the ground, I am assuming these cables are supplier earth rods as they didn't look fat enough to be power cables.
I spoke to a friend and he said it looks like the supplier is going to upgrade the whole area to PME in time.
However I was told at college a while back in 16th edition that overhead cables should be earthed via TT system because overhead cables are more likely to suffer a neutral fault and hence you would lose your earth aswell. I was told this a while ago and I could have got this fact wrong.
So my question is if the supply is overhead is it better to use a TT system or to use a PME system?
I just wonder what would be the best earthing arrangements for this scenario.
I understand that any TT system must be RCD protected to max.
Thanks.
Thanks.
