Overhead Supply with PME, DNO? | Page 2 | on ElectriciansForums
Discuss Overhead Supply with PME, DNO? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
If installation not bonded then it should not have been connected. I worked 50 years for dno, pme had to be set up with over head neutral earthed, usually every second pole.
Reply to Overhead Supply with PME, DNO? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
That traffolyte label glued to the service head is the same as those screwed to the wooden support poles.
Hence the former name for TNC-S, PME. Protective Multiple Earth.
