Overload? | Page 2 | on ElectriciansForums
Discuss Overload? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I did not know it was 13k!!!! The shop owner "reliably"told me it was less than 50amp
Regarding the customer who i assume isn't an Electrician saying its less than 50amp supply then i think you are just learning a valuable lesson here and im sure you will take steps in future to confirm the customers figures for yourself... what is a concern is you seem to have forgotten to do basic cable calcs which in your set-up could see the cable rating reduced to less than 50amps although we lack info to clarify this but i probably would assume due to the methods chosen that you can't increase to 63amp.... can you detail more about the install methods like length and insulation etc
Reply to Overload? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
Since my last post I have used the oven several times and it is still working ! On reading the 'regulatory' position I will ask an electrician to...
