Ovo won't Fit a Smart Meter. | on ElectriciansForums
Discuss Ovo won't Fit a Smart Meter. in the UK Electrical Forum area at ElectriciansForums.net
Santa
My daughter wanted a smart meter but when the fitter came he said he couldn't fit it because "the meter is on the same board as the CU".
I don't have a picture and she lives 120 miles away, but I do know that it is all in her understairs cupboard.
Is this something to be concerned about?
Some suppliers insist that only their equipment (i.e. Meter, supply fuse) are fitted on the back board that they have supplied.
Usually the back board is marked "suppliers equipment only".
If that is the case, the electrician should not have fitted it there.
No replies yet that are actually helpful then.
I have a smart meter and it is fine.
Whoever originally wired the house before they bought it did the job. My question is - Should she be concerned that the CU and the meter (and presumably the main fuze) are on the same back board. TBH - I thought that was how they were usually fitted.
Thanks guys - confirms my own thoughts. The cupboard is fairly small and most likely added after the meter was fitted. My guess was that he just didn't fancy the job - maybe was running late, and used it as an excuse.
anyone who needs a smart meter to communicate his/her electric usage to his/her supplier when we have telephones/email/internet needs to do a course in communications. i think talkskills4U do one. it's 5 weeks and at the end of it you can talk the arse off a donkey.
You haven't tried to change energy supplier yet then?
apparently the software will not be compatible with other suppliers till next year sometime.
Reply to Ovo won't Fit a Smart Meter. in the UK Electrical Forum area at ElectriciansForums.net
It sounds like the original meter was reading incorrectly and octopus aren't keen to admit this as they would probably have to refund you. I...
davesparks
Given that, it probably makes sense to TT the shed, unless you can be sure it doesn't act as an extraneous-conductive-part. (The SWA won't have...
