P.A.T Testing I.T. Equipment | on ElectriciansForums
Discuss P.A.T Testing I.T. Equipment in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
P
PAT ukLtd
On 'Pattesters' website they advise-
When testing modern IT equipment it is not normal to performed a leakage or touch current test; these tests are usually used on older equipment in place of the 500 Volt insulation test.
However in my copy of the IEE they say that touch current test should be used.
So if you are not using a leakage or touch current, I presume the only tests they are saying used on it are visual inspection & earth continuity test.
Correct!! The reason being; modern PC's momentarely start up when you apply power, then shut down automatically after about 10 seconds. When PAT testing the applied test duration is around 5 seconds. When 2 short bursts of power is applied to modern PC's
there is a potential of them "crashing".
Reply to P.A.T Testing I.T. Equipment in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
I was at the other end of the results spectrum today. As I was driving home I had a call from my "Mrs Richards from Fawlty Towers" lady, very deaf...
  • exceeding voltage drop
    The cable is way undersized. If the voltage drop is detrimental to the installation I would make...
  • TT advise
    OK My take on the precautions to implement when omitting an up front RCD on a TT system. Tails...
  • SIL vs ATEX
    Good morning all, I have a question for those who are CompEx and SIL aware - I have various Ex...
