paint ceiling 1st or drill holes ? | on ElectriciansForums
Discuss paint ceiling 1st or drill holes ? in the Lighting Forum area at ElectriciansForums.net
Deleted member 112675
Hello Everyone
I have a freshly skimmed ceiling with no holes. Planning to have some downlights installed.
Obviously I have to mist coat then paint ceiling but should the holes for the downlights be drilled before or after?
My thinking was if before then wet mistcoat paint might drip all over the holes and if drilling the holes after, then maybe the plaster dust will ruin the freshly painted finish.
Anyway what do you do and why?
Thanks for taking the time !
drill holes first, have you sorted the cables to the holes yet? if you haven't involved a spark yet, now is the time to do so.
edit,
my thoughts behind this are if you drill holes first, any errors can be fixed before final paint coat.
I.e. when you drill a downlight hole and it is half over a timber.
easy to fill and plaster when not painted, will blend and disappear.
As ever, many thanks for all your replies!
I should have said I do have good access from above. The wiring isn't done yet. I skimmed first because I did it myself, its a big room and was only just about within my limits. Having 12 holes would have made it that much harder.
So from now consensus seems to be to drill holes first in case I make a mistake. Cans are Enlite DLM982X . (I've made the mistake before of fitting cheap cans and didn't want to make it twice!). They have seperate bezel.
So I'm thinking:
1/ mist coat the lot
2/ measure and drill holes
3/ fit cans, wire up and test
4/ final paint
5/ fit bezels (and gu10s!)
Its in a bedroom......
Paint first and then fit afterwards, use a dade and just hoover any remaining dust off. Fit a decent downlight where it actually fits the cut out size, I always try to use Enlite E5's and never had an issue, had plenty of issues with GU10 downlight cans though!
As always, at the risk of being a stuck record, you should be getting an electrician to undertake and verify this work. Regulations, personal safety, home insurance, etc. Lots of reasons.
And 12 is far too many for a bedroom, unless it's big enough for 2 kingsize beds, room to manoeuvre, and an ensuite.
...or they're the very small downlighters ?
Yes. Just noticed OP is using cans and GU10s so may suffer from the pimple ceiling effect common when using halogen GU10 with tight beam angles.
I don't think I've ever put more than 4 integrated downlights in an average sized double bedroom.
agree. 4 - 6 dimmables would seem more realistic. ( course, OP might be making naughty videos, in which case 12 might be required.)
Reply to paint ceiling 1st or drill holes ? in the Lighting Forum area at ElectriciansForums.net
If you have a plan for the downlights, and all you are doing is cutting out and fitting them then yes, 8 downlights in 4 hrs is slow. Fixed price...
I think I know exactly the stuff you mean - called insulating board (I think) and it's like the stuff you get on pin boards for thumb tacks. I...
