Hi All
I got a solar panel installation nearly a year ago. (Nov 2015)
12 panels (Sunmodule Plus SW250) on the roof and 4 on the garage roof (same direction nearly the same tilt)
Faces S; minimal shade; I'd guess about 40 degree tilt.
12 panels are tied to 1 inverter (Afore HNS3000TL-1) and the 4 panels to another inverter
(Afore HNS3000TL-1)
Since it started, the generating meter reports 2926 (Kw I presume?)
The two inverters report 2512Kw and 611Kw
So:
- Is 2926 a reasonable output for this system over the last 9 months?
- If the panels are the ratio 3 to 1 (12 to 4), why is the inverter output in the ratio 4:1 (2512 to 611)?
Does this suggest I have a non-working panel in the 4 panel array or is it just a measurement error or what?
I did ask the inverter company but they simply said the inverter meters are not calibrated so you cant tell anything but said they come and look for £250!
Seemed a load of b*l*o*k* to me. If the meters are that inaccurate what is the point of having them?
(Afore HNS3000TL-1)
So:
