parallel cables | Page 2 | on ElectriciansForums
Discuss parallel cables in the Australia area at ElectriciansForums.net
K
keith@kbw
can any help me, i need to install 200amp three phase supply at 135m long, i wish to run two smaller cable insted of one large size cable, so can any one tell how to calculate for parallel cables supply.:confused:
400mm? have you ever pulled a 400mm 4c ,i,ve pulled 300mm 4c & singles upto 1000mm
but your talking high current way above the 120a that started this thread .My college days
are long gone but i still reckon 2x 70mm 4c will do it.
But back to the original thread it doesn,t give you a clue as to how the cables could be installed so you don,t know what the correct factor to apply so more info needed
yours benji
sorry 120a should read 200a but still reckon 2x704c
benji
yours benji
benji
No no, i was just using the size as an example and showing to divide the CSA by two for the correct cable size.
Reply to parallel cables in the Australia area at ElectriciansForums.net
https://sravivarman.com/technical-articles/parallel-operation-of-thyristors/ Series resistor, or bigger series resistor, needed?
