Parallel paths on R1 + R2 test | on ElectriciansForums
Discuss Parallel paths on R1 + R2 test in the UK Electrical Forum area at ElectriciansForums.net
DaveS
London
Hi there
Doing some testing at moment. R1 + R2 readings coming in lower than R1 + Rn. Cpc neutral and live all disconnected. There is alot of containment on job and adaptable boxes are all fly leaded to earth. My thoughts are they are parallel earth paths but guy working with seems to think because cpc disconnected at board it can' be. Who is right basically? Thanks
Hi there
What are the r1, rn and r2 readings?
0.92 on r1 + r2 and 1.25 on the r1 + rn both wired in 2.5mm
Don't think you understood my question Dave end to end readings r1,r2 and rn as seperate conductors, as described in the RFC testing procedure. From your statement the circuit is wired in singles 2.5mm2,
It could be that you have a poor connection in one of the conductors, proving the end to end resistances will settle the arguement.
Are you nulling the leads at the ends of each test?
if it's in metal containment that will provide a parallel earth so the R2 reading will be the cpc and metalwork in parallel.thus giving a lower reading.
Hi Pete I don' think I can do end to end readings as over multiple floors? The leads were nulled yes. Have just tested a seperate circuit and how similar readings with a 0.30 lower difference again with r1 + r2 this does parallel paths no?
You can do end to end testing at the CU Dave
I'm confused how this could affect the carrying out of end-to-end readings. I might be missing something.
Reply to Parallel paths on R1 + R2 test in the UK Electrical Forum area at ElectriciansForums.net
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
I believe that it is incorporated into the 5 days. But will double check. Thanks.
