Park homes | on ElectriciansForums
Discuss Park homes in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I have been asked to carry out a periodic inspection on a caravan site with static caravans only (not tourers ).
Can any one tell me if the maximum periods between inspections is the same for static parks as for touring parks?
and the same question for the caravans ?
Thanks for any help:D
Thanks Brizo, however the question was really is there a difference between static caravans/park homes and trouring caravans?
PIR every three But a Routine inspection every year, condition and function of accesories, RCD operation at a point in the circuit NOT in isolation, Zs at a socket and light fitting but again if there is no previous inspection report of any kind to compare with it,s a full EICR,
Reply to Park homes in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Thanks Risteard. I had put it down as a 2, even though I wasn't sure if I was right in doing so. Good to hear you'd have done the same. Thanks for...
I don't really know if he is or not, but I would have thought an electrician would be able to calculate cable size or know about requirements for...
