Part 1, how to install outdoor lighting. | Page 2 | on ElectriciansForums
Discuss Part 1, how to install outdoor lighting. in the UK Electrical Forum area at ElectriciansForums.net
L
lister
This is just one of the many jems that i come across on a regular basis, (yes even with the invention of part p and its strict policing) i thought i would share with you if only to cheer someone up.:grin:
Step 1;
Don't bother wasting time drilling a hole share one that's already there......
[ElectriciansForums.net] Part 1, how to install outdoor lighting.
then run cable along the Bathroom wall (yes bathroom, with a shower)
extend with a bit of terminal block......(still in bathroom).....
use 4" of cable to go through wall then extend again.....
Don't bother with that centre bit of wire (there's no rcd anyway), try not to worry about the burn marks on the paint job or trip on it as you come down stairs.......
connect via a socket because there always handy, don't worry about fusing or isolating any thing that only takes more time...
securely clip cables to wall...................
extend once more, you only need twin terminal block as you omitted earth a while ago.....
and finally install outside lights.
Reply to Part 1, how to install outdoor lighting. in the UK Electrical Forum area at ElectriciansForums.net
I've made the required tweaks on the junction box with a 4mm hole bottom, upturned wagos and reduced the exposed copper. I did originally install...
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
