Part M regs? socket heights and other important regs | Page 2 | on ElectriciansForums
Discuss Part M regs? socket heights and other important regs in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
kris jones
Mentor
shropshire
Hi All,
For my own knowledge I would like to easily access some of the fundamental regulations such as minimum distances for sockets and locations of 'stuff' to comply with current regs.
Ive a copy of the 17th edition but I struggle to find anything even with the table of contents!
I need something that says 'If you install a socket it need to be 450-1200 etc' - easy to understand and find
Is there anywhere online that some of the most important (not that its not all important!) regs can be easily found? Ive tried but Im needing a little help.
Thanks in advance.
I wrote this list of the building regulations requirements applicable to electrical work, it does not cover BS7671 as there is too much to cover there, but covers the additional specs of the building regulations.
This was written some time ago so may not be up to date, I have had a quick check and it should be close, but may be a useful reference.
  • Building Regulations Parts Applicable to Electrical Work.pdf
Upvote 0
Reply to Part M regs? socket heights and other important regs in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Do you have an iPhone? If so you can take scans that “flatten” the image through some technical magic via the Notes app, these are auto saved as...
Hi I'm again struggling with a long overdue 2396 project but, as before, am at a standstill when it comes to the lighting design. Please could...
Electrical Courses
