G
Guest77
It is a Building regulation, thats right a Building regulation, not a Electrical qualification. If you read it (you can download it on-line) then you will see that some works, and only some as it is getting less now needs to be notified to the local building control. Now there is nothing to suggest an Electrician need notify the local building control authority, nothing at all anywhere, this is a myth, and a myth we are all getting fed up with. The customer is duty bound to do this just like if they decided to have a loft conversion or indeed a extension on their home. To be competitive some electricians join a scheme so they can notify for the customer on their behalf and the fees are usually a couple of quid instead of the 2-300 the local authority would charge the customer if an Electrician didn't do it for them, this way the customer gets to save some money and the Electrician wins work. The schemes have a policy which they suggest if they get people to join them they will guarentee to the local authority the people they approve are competant, for this privilage they take 400-500 off these people, usually Electricians, but some Plumbers and Kitchen Fitters join as well, The local authority building control then accepts the fact the people on these schemes are competant and do not go out to site to inspect the works, this is why the cost is just an administrative one at a few quid and not hundreds. If you are a competant Electrician for example with a Gold card and plenty of experience why do you need to pay a scheme hundreds of pounds a year to have them tell the Local authority you are competant? If you are Competant then get stuck in and start work. If the work you do does need to be notified then you can ask the customer to do it or include an extra couple of hundred on top of your quote for you to do it. There is no judge in the whole of the UK who will find you guilty of anything wrong doing if you carry out work to BS7671 correctly without being a member of a scheme, we don't need them do we? so why are we paying them 500 a year? I can confirm I no longer pay them, I have left the NICEIC, I am competant, I have over 30 years experience, I will not give them 500 quid to tell someone else I am competant.
Please do not keep going on about being part p qualified, it is all Rollocks, rant over.
