Part that can replace DIMPLEX2000330100RP? | on ElectriciansForums
Discuss Part that can replace DIMPLEX2000330100RP? in the Electrical Appliances Forum area at ElectriciansForums.net
USA
I'm looking for something that can replace this part for my electric fireplace:
[ElectriciansForums.net] Part that can replace DIMPLEX2000330100RP?
Getting the exact part is rather expensive, so I'm hoping someone can suggest a cheaper alternative that will work.
You need the correct Dimplex part to fit your fireplace. Similar (but not correct) parts with different numbers will probably not be physically interchangeable without modification, and potentially be a safety hazard.
You might find a reduced or used one somewhere, possibly on eBay, but use at your risk.
You could always use an alternative source of heat 🤔
Reply to Part that can replace DIMPLEX2000330100RP? in the Electrical Appliances Forum area at ElectriciansForums.net
M
Rubi DC-250 1200 Water Pump Replacement Hi, I'm really hoping someone can maybe help. I have a Rubi DC-250 1200 and it looks like the water pump...
M
This is an RSS feed of thread: Combi Gas Boiler Intermittent Problem - Need to identify replacement part? Content of the thread: Hi All, Combo...
