I'm about to start some work on a detached garage. Sockets lights etc etc.
From the supply head there is a 63A switch fuse, that takes a set of 25mm tails to the board which is situated about 4m away.
From the board it goes in 16mm 3c SWA to the garage where it is terminated into a four way Metal clad DB.
so for my testing, is the origin of this install at the consumer unit in the house or the switch fuse?
for the test sheets do I record each sub main on my test results or just the one that supplies that garage?
as I have not installed any of it i'm just doing the garage install this will be recorded but i want to make sure I record the right things, previously i've done the whole shooting match so there's been no confusion.
one last thing, To eliminate the risk of parallel paths on the earth it is correct to only terminate the swa armour to earth at one end. is it acceptable to do this at the garage end?
normally i'd do it at the supply end but at this supply end it is plastic and at my end it is a metal db. assuming the answer is no - has to be connected at the supply end how do i go about it at the other end? plastic washers?
Thanks in advance
dave
Thanks in advance
dave
