View the thread, titled "Passing 17th Advice please" which is posted in Electrical Wiring, Theories and Regulations on Electricians Forums.
Sorry to reiterate what others said but it's true you just need to be able to find stuff in the BS7671 book. Best way IMHO is to get that lecsoft software that someone else mentioned. It's what I did and I just did a few mock exams. Lots of the questions reappear with a slightly different angle but you get used to finding where you need to be in book.
Good luck!
I deliver this course, and can give you a few pointers, and tips for success.
Firstly, spend about 3 or 4 hours going over Parts 1,2 and 3, then get hold of some practice papers, and do questions 1 to about 18 or 19. Because the exam questions follow the layout of the book, the first questions will be from parts 1,2 and 3. This will get you used to finding your way around a small part if the book. Next spend about 4 or 5 hours just on Part 4, protection. You will get 15 or 16 questions on part 4, make sure you know your stuff on additional protection, reg 415.1.1 in particular, then try questions 20 to 35 ish. Part 5 selection and erection, this is where you will start to get heavily involved in the appendices, you will have ventured there in the other parts, but it gets major in part 5 and straight from the off. Again 5 or 6 hours on part 5, get used to jumping back and forth into and out of the appendices, then attempt questions 36 to 50. Finally spend 3 or 4 hours on parts 6,7 and the appendices, as these parts are quite well laid out and easy to navigate around, try the last few questions. If you are happy, then try a full dress rehearsal with a different practice paper. Good luck.
Before you decide to spend the national debt on books etc, and use up all your time, i would make sure you can find a centre which will let you take the exam without doing the course, most won't, including where i work.
Cheers.........Howard
Thanks for the advice, I pretty good as it stands just want to make sure I have all the bases covered. I would have brought the green book and the OSG even if I wasn't doing the exam. My office is full of old reference books going back to my collage days. lol
Reply to the thread, titled "Passing 17th Advice please" which is posted in Electrical Wiring, Theories and Regulations on Electricians Forums.
woodencupbaord,
Cazmac1,
