PAT...an alternative... | Page 2 | on ElectriciansForums
Discuss PAT...an alternative... in the UK Electrical Forum area at ElectriciansForums.net
NDG Elecs
Nearly Esteemed
Tyne and Wear
Hi folks,
I don't do PAT. Never had, never done CG course, and not got tester. Nor never had the inkling too TBH..
Occasionally I am asked if I could PAT an individual appliance, to which I say well not really. I say I can check for earth leakage and give it a visual (internally also if feasible), but do not have the know how or tester to do anything else.
My question is are there any other things with the typical appliance I can check for bearing in mind I have a MFT/anologue multimeter/VI/clamp meter/leakage clamp meter/etc.. I can't think of anything off hand except checking for correct fusing, worn cables etc...
The earth bond test on a class one appliance should be carried out at 25A for obvious (hopefully) reasons. The problem with using an MFT or a battery powered tester is they can't deliver that current.
Good point. MFT would be less useful for class one stuff. Daz
Visual inspection is critical and should be performed before testing: plug, socket, lead, connectors, connections, body of equipment, controls of equipment.
Testing:
Earth continuity (on class I only)
Insulation resistance testing (or protective conductor current / leakage test)
Functional test(s)
Records: extensive: equipment register, test and inspect register, fault register, repair register
Limits:
Earth continuity (R is supply cable cpc resistance)
Equipment and supply cable; <= 0.1 + R Ω
Equipment only; <= 0.1 Ω
Class I heating and cooking equipment >= 3kW: >= 0.3 MΩ
Other class I equipment; >= 1.0 MΩ
Class II equipment; >= 2.0 MΩ
Class III equipment; >= 0.250 MΩ
Protective conductor current
Portable hand held class I; <=0.75 mA
Class I heating equipment ; <=0.75 mA (or <=0.75 mA/kW) max 5 mA
Other class I ; <=3.5 mA
Class II; <=0.25 mA
Class III; <=0.50 mA
Frequency of inspection and testing determined by risk assessment, guidance in the COP.
Reply to PAT...an alternative... in the UK Electrical Forum area at ElectriciansForums.net
I used to do a lot of this. My go - to was testing at the load side of isolators etc where possible. Although of course you'll find plenty of...
