MTS
Hi, can anyone advise please. I am making up a earth bond lead for a meteral PAT tester just purchased as did not come with one. Its the 3 pin XLR connector common on a lot of testers. My question is how is it wired? Can i use 3 core flex and solder one wire to each pin in the connector then connect all 3 at the other end to the crocodile earth clip. Or as its mutipole does each pin have a seperate function.? Thanks
