B
bertbuckie
And to top it all off, I have young kids, live is VERY exposed ( my 7 year old actually pointed the hole out to me, good lad! )
From my experience every time of have found heat damage like this it been due to loose or poor ccnnection at terminal points , asit was on the neutral on the molded plug and then on the live on the replacement plug , i would say that the molded plug had a bad connection neutral (may of been a comon fault at the manufacturer ,and )the new plug had a bad connection either at the connection or on the fuse holder. If you can take thecover of the plug you may see exactly were the point is , somtimes on cheaper plugs the fuse holder clips never seam very good just my opinion.Hi Flanders, the engineer who did the plug from knowhow left the cardboard on lol, I shall try and get an amp meter as I would imagine its towards the end of the cycle it draws the most current tbh.
Someone also said cheap socket and plug... twice ?
What's your reasoning behind that statement?Hi Flanders, the engineer who did the plug from knowhow left the cardboard on lol, I shall try and get an amp meter as I would imagine its towards the end of the cycle it draws the most current tbh.
'Spin only' on a tumbler drier? What purpose does that serve or is this a washer drier?Reasoning is as the machine uses the heaters as opposed to the spin only. Spoke directly to the company director at know how and we are getting a new dryer, similar faults have been found on others it seems.
