PAT Tester broken but i can use megger? | Page 4 | on ElectriciansForums
Discuss PAT Tester broken but i can use megger? in the UK Electrical Forum area at ElectriciansForums.net
london
Hello guys
my seaward PAT tester has given up the ghost, i have some small PAT jobs coming up and was thinking short term of being able to just use my multi function meter.
R2 test on class 1 equipment using low voltage ohm meter
Insulation resistance testing with leads
Trying to think what other limitations i have by just using my multi function test instrument?
Still remember when everything from Japan was made from tin (cans) and laughingly called Jap Crap. Then they bought the old assembly line for Austin and using the engine and chassis components designed their Datsun Bluebird. Datsun became Nissan and with Honda,Toyota etc, no ones laughing now. Maybe Chinese will catch on, they are losing “Face” big time!
Reply to PAT Tester broken but i can use megger? in the UK Electrical Forum area at ElectriciansForums.net
Yes that was me. If you change your mind give me a shout and I’ll sort something out for you 👍
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
