Discuss pat testing dishwasher in the Electrical Appliances Forum area at ElectriciansForums.net
LOL just checking out my tester
Why are you PAT testing your dishwasher?
Good idea the plug was easy to get to though.
would you say the readings a bit low?
This is normal for a dish washer it will have a radio-interference suppression unit fitted which has a 1M resistor across Live & neutral. with some caps thrown in for good measure. Did you try the protective conductor touch current measurement?http://www.iskra-mis.si/catalogue/2010053111092173/2010060309004249/when pat testing my dishwasher on insulation res i get low reading of 1M ohm does this comply?
Reply to pat testing dishwasher in the Electrical Appliances Forum area at ElectriciansForums.net
