N
nickjowett
Hi I have been responsible for the PAT testing at work for the past 8 years and in general all is well apart from one situation that arrises almost every year. I have just tested the kettle in the staff room and at first couldn't get a continuity reading at all. The kettle sits on a base with the Earth connection being made when the kettle is put on the base. I cleaned the contacts with wire wool and got a reading of about 0.2 ohms and even if I could get the kettle to pass with a bit more cleaning of the contacts I would be reluctant to do so as I am sure the readings would go up within a short time. Over the past 8 years this has been a recurring problem and I have thrown at least 6 kettle away. Does anyone esle have this problem.
Nick
Nick
