OP
tdunbar
Well lo and behold Whirlpool has come back and advised me it has referred my query to its factory. What was the problem with doing that earlier?
Discuss Pat Testing Whirlpool Freezer. in the Electrical Appliances & Whitegoods Forum area at ElectriciansForums.net
It's class 11
Does the freezer pass the PA Test?Whirlpool chest freezer. Earth bond to compressor. No earth bond to casing.
Contacted Whirlpool for clarification and got reply as follows:-
"Dear Mr Dunbar
Thank you for contacting Whirlpool UK
Regrettably I am unable to offer you any technical resolution and would only recommend for a Whirlpool
engineer to attend and diagnose.
I am sorry we were unable to be of any more help at this time.
Regards"
Wouldn't you have thought that the Whirlpol itself would be able to advise on this. I think even the COP 4th Ed, also recommends contacting manufacturers on issues.
Anyone help with matter of no earth bond detected with casing please?
Thabnks
Is this somewhere I can reference to as there is no class 2 symbol and a metal case and COP regs would mean a class 1 earth. I'm sure the IR would show it to be safe enough but I need to make sure I'm covered by regs I can show.The advice I received in a similar situation was to do an IR test from the earth to the exposed metal. I can't remember the limits, but if the value is sufficiently high I don't believe it needs to be earthed.
I asked because I was doing an EICR and could find no earth continuity between the RFC CPC and the exposed metalwork of the fridge/freezer, but there was continuity to the compressor cradle at the rear of the unit.
Reply to Pat Testing Whirlpool Freezer. in the Electrical Appliances & Whitegoods Forum area at ElectriciansForums.net
