PAT. Visual Inspection Only | Page 2 | on ElectriciansForums
Discuss PAT. Visual Inspection Only in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Visual inspection is a Part of the PAT testing sequence, NOT a replacement for PAT testing!!
Why would you not IR class 11 appliances like ceramic lamp holders?? The only test you can't perform is ''Earth Bond'', that is replaced by a Class 11 flash test. As far as i know, you only visually inspect casings and cords/plug tops for damage, everything else is to be tested!!
Complete waste of time, to only conduct a visual inspection, totally meaningless and a waste of paper and sticker!! lol!!
Complete waste of time, to only conduct a visual inspection, totally meaningless and a waste of paper and sticker!! lol!![/QUOTE]
Not entirely correct. There are plenty of class 11 appliances that you can only do a visual inspection on. Phone chargers are an example. If a class 11 appliance is entirely plastic cased there is no point in IR testing it because the PAT tester carries out the test by joiniing L-N and testing to the earth pin.This is what the blue 'visual only' stickers are intended for.
If a class 11 appliance has exposed metal parts an IR test can be carried out with the auxillary probe on the metal part of the appliance to 'replace' the missing earth connection.
Another example might be computers,which are often undisturbed from year to year,if a computer is tested one year it would be perfectly reasonable to do a vis only the next.
Just because some abuse the vis only check does not mean it does not have a place in proper pat testing.
Yes agree, with your comments, on some class 11 appliances, but with many of the appliances on the computer side of things, a low current earth bond test is available on most PAT testers. As far as class 11 ceramic table lamps and the like are concerned an IR L-N test can be performed with a standard IR tester. Not sure if anyone would try and PAT test a phone charger though!! Hmm, thinking about it, i dunno though!! ...lol!!!
Why on earth would you pay someone to put a sticker on a phone charger whoever is using it will see whether it is damaged or not. This visual inspection is a money making cop out to protect idiots
Agreed, I actually thought that after I'd posted :blush5:
I see your point with phonecharges wirepuller, but i still can't see the point in a blue sticker for visual only. Someone could smash it to bits 30secs after you've walked out the door.
[QUOTE E54;711779]
When I first joined this forum I got into a 'discussion' with a guy who insisted all portable appliances could and should be tested....when it came to all insulated phone chargers he said it could be IR tested by using the auxillary probe on the (plastic) case!.....thats the level of intellegence of some of them.
Same applies to a 'tested' appliance.
Yep, and thats why i see the whole 'pat' thing as completley pointless lol.
Maybe i should stop being so anti-pat and try and embrace it for once!
Just read that thread...or as i would call it, a rant wirepuller :tongue3:
You hit it spot on with that thread to be fair, and illustrated how incredibly pointless the whole thing is.
If anything was to go wrong with any of the appliances them fellas stuck the sticker on...all they would say is ' it was fine / not broken when we tested it' and theres nothing to really prove them wrong. Thats how they get away with charging ÂŁ0.15 an appliance.
Like you, i only have a few pat tests to do a year for regular customers...around the 11th of may, when the 2 small b'n'b/hotels i cover are due...i never want to get out of bed lol. Absolutley hate it.
Crazy thing is its an open secret that it is a mess yet the HSE review that pushed for a revision ie 4th edition has not made things any clearer
Reply to PAT. Visual Inspection Only in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I used to do a lot of this. My go - to was testing at the load side of isolators etc where possible. Although of course you'll find plenty of...
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
