patch panel | on ElectriciansForums
Discuss patch panel in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
B
Buzz-light-bulb
Good morning every1
I'm new to forum and this is my first post so go easy on me.
Just a basic question for all you intelligent people, I'm doing an eicr On a communal installation which contains an office, I need to turn power off to test ring main which has a patch panel plugged in, if I turn off will it just reset back to normal.
Thanks guys much appreciateted for your replys.
get the manager to organise logging the computers off the server. it should re-boot automatically when power is restored.
^^ correct , 9 times out of 10 you get away with cutting the power and its fine comes back up no bother but if it goes wrong , it really goes wrong
Reply to patch panel in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
