JIB Electrotechnical Certification Scheme (ECS) Path from Domestic Installer to JIB.
Search the forum,
Discuss Path from Domestic Installer to JIB. in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
CRog92
Hi Guys,
I'm looking at doing a course to become a DI but I don't want to just be doing residential maintenance forever, i'd like to work on site eventually but have been told I would not be able to unless I work as a mate or do the 2365 level 2 and 3 and the NVQ 3 after and I don't have the funds at the moment to do the 2365 and so on.
The course I'm looking at doing gives me the following quals:
Principles of Electro Technology – City & Guilds 4141-02
Domestic Installation Workshop – City & Guilds 4141-01.
Part P Domestic Installers Course – City & Guilds 2393.
17th Edition Wiring Regulations - City & Guilds 2382-15.
Inspection & Testing Course – City & Guilds 2392-10.
PAT Testing - City & Guilds 2377-22 & 2377-32
Any advice would be appreciated.
Thanks.
If you do this domestic installer course with a view to eventually gaining a NVQ to gain a ECS graded card for site work, then you will have to start from scratch when you go the NVQ route.
The domestic course is a selection of parts of the 2365 content and will limit you prospects wise and knowledge wise.
If you want a NVQ in the end, then make it your goal and starting point.
Hi,you say "just" a domestic installer...to be good at that,you would need more than just a course,you would need a rake of experience,too.
Do not think,that any course,bypasses the need for real experience and some slog thrown in.
It will be this experience,which allows any future academic input,to soak in,and make sense. :)
If you really want to become a qualified electrician then do the 2365 on an evening at college. Should be cheaper than the courses you are looking at doing for the DI.
Then try and get a job through the day as a labourer/mate. With a bit of experiance and after completing the 2365, you can then do the NVQ.
Good things come to those who wait and all that!
Jay
City & Guilds 4141-01 - Electrical Installation Work within a Domestic Dwelling What is this qualification? Sounds made up to me, won't get much recognition in the industry and you'll probably struggle to get a job. Micky Mouse springs to mind.
City & Guilds 2393 – Part P Building Regulations This is NOT a qualification.
City & guilds 2392-10 – Inspection & Testing Course This is NOT a proper inspection and testing qualification, this is only at level 2standard. 2394 and 2395 are what you need, not this.
City & Guilds 2382-12 – 17th Edition Wiring Regulations (Including latest amendments) About the only thing recongisible from the above list - and again, this is a joke, any muggins can pass this.
Would this be a good starting point to become a domestic installer No.
Copy and pasted off bobit.
I’d echo what others have said and do the college course mate over a longer period. Cramping everything in such a short time in this industry is asking for trouble IMO.
Being an electrician is a long drawn out out process which takes yrs to become competent properly and short course are just about making money and getting you through it while not addressing the fundamentals throughly.
Bets of luck what you decide.
Give the PAT testing course a miss
Jay
I feel Bob Mugabe,would dispute this :cool:
PA testing! Sahara Sahara!
My advice is make sure that the C+G you do partake in has a bridge course that can allow you to do the AM2 and be able to get a gold card if you want one. I’ve got the 2397-30 (domestic installer) which has a bridge to get the 2357 which the apprentices do in commercial/ industrial with the AM2.
With so many courses to choose from you could ‘paint yourself’ into a corner for want of a better ‘trade’ pun!
I’ve been doing commercial agency work the last 7 months to get the experience and evidence for when I need to bridge that gap.
Research previous threads on this forum for extra views.
Reply to Path from Domestic Installer to JIB. in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
