Pattress for old MK socket | on ElectriciansForums
Discuss Pattress for old MK socket in the For Sale and Wanted Forum area at ElectriciansForums.net
sionevans
East Grinstead
Looking for a metal pattress with screw fittings in the correct place for this old MK 2 gang
[ElectriciansForums.net] Pattress for old MK socket
socket.
The existing pattress of the socket that I am looking to replace has fittings on the side.
Really useful site, thank you @snowhead
I love places where you can get "stuff" not easily obtained elsewhere. The range of fabric covered flex is amazing, and I love the "large" ceiling rose that will cover the mess under an older, small or standard rose
Dual boxes are slightly wider and it's unlikely those lugs are correctly spaced. It also has a divider that would prevent the socket screwing back.
The prior link is for a standard 2 gang flush box with 'back box repair clips', which Google will show you, but obviously you'd have to set spacing without the aid of a convenient template.
Older -style but modern accessories google search brought up the art deco site mentioned earlier in this thread...
and also this:
I probably won't be replacing all my switches with these!
The double sockets are a bit cheaper though...
To continue the theme, I am beginning to construct a "vintage" board using older accessories.
My house actually has a couple of those old MK sockets with the 4 fixing screws, but I have a couple of other MK sockets, pictured here with an old light switch.
The diagonally opposed fixing holes on the white socket are a bit unusual, to me anyway, and the neat format, as also the neat format of the brown, round pin socket, please my eye.
Question:
The fixing screws are not the current 3.5mm. but smaller...I'm guessing 2.5 or 3mm. To save me searching, I'm sure somebody can confirm the size and a supplier.
The screws for the white socket were also captive, they never fell out although yours are missing. Tough as old boots they rarely need replacing unless they have suffered severe mechanical damage.
Reply to Pattress for old MK socket in the For Sale and Wanted Forum area at ElectriciansForums.net
Fitted a lot of this sort of light recently, with all tests reporting back through central Dali controller(s).
nicebutdim
N
The legs on the bus bar are too long for the new rcbos
