Pattress sticks out from plaster work | on ElectriciansForums
Discuss Pattress sticks out from plaster work in the Australia area at ElectriciansForums.net
O
orangegoblin
Hi Forum
I have rewired my house and then had a plasterer come in and skim the rooms. He hasn't plastered level and in some cases a few millimeters of the pattress sticks out of the plaster. As a consequence, there is a gap around the switches and they are not flush to the wall.
Do you know of any raised finger plates or something similar that can cover this up. I have already had a go at the plasterer, but i cannot have re-skim done. I am happy to use finger plates, but i have struggled to find any raised plates.
Can anyone recommend any?
Thanks in advance...
Sounds like you prolly didn't sink your boxes quite deep enough, or the plasterer is a total redneck (which isn't unheard of.) Taking the boxes out may bring some wall out with it so more making good. You must be able to buy raised plates but cant honestly say I've ever tried. It'll look cack too
I can remember years ago in my aunt and uncle's house they had these clear plastic surrounds around their light switches. you had to loosen the switch off then slot these things around them. They were probably a couple of mm thick but looked bloody awful. They're more than likely still available and may be the solution to your problem if you don't fancy chopping your boxes in properly
Reply to Pattress sticks out from plaster work in the Australia area at ElectriciansForums.net
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
