PC-Case conducts energy | on ElectriciansForums
Discuss PC-Case conducts energy in the UK Electrical Forum area at ElectriciansForums.net
Deleted member 110184
Hello there!
First of all, i am not an electrician and i am absolutely new to this. I have a Problem with my PC and am seeking for advice on how to handle it. I hope this is the right place to post this Thread, if not please let me now.
I just built a brand new Computer with all new components but i have the problem that my PC-Case conducts energy. This means as soon as i touch anything that is made of metal from the case i can feel the energy on my finger. It really is a constant shock and not just a short shock you would have with static electricity. First thing i did was to buy an outlet tester. I checked all the outlets for errors but all of them are all right.
attachment.php
I do have an UPS between the Outlet and my PC. So what i want to test now is if i plug out the energy from the Outlet and i run my PC only over my UPS, if i still get that shock. The Problem is, i really dont know how to measure the Voltage of the PC Case correctly. I do not know where i have to put the Voltage and the Ground Pin from the Multimeter to measure the Voltage of the case. Can anybody help me out with this??
Thanks!
1st thing is to measure from the case to a known earth. try on both ac and dc ranges. test again with the UPS out of circuit.
99% certain your computer is not effectively connected to the earth of the 13A plug. It is difficult to advise a way forward as you do not have suitable test equipment and we cannot advise that you keep touching it to see if it has disappeared.
You can use a multimeter but it may not give an effective result. Turn off the mains power to the socket and set your meter to low ohms then test between the computer casing and the socket earth with the computer plugged in and it should show continuity, if not then it is not earthed. Ensure power to the socket is off when you do this!!!
You will notice that socket tester in the picture does not detect neutral /earth crossed over.
Use meter to check continuity of case to earth tag on schuko plug not plugged in.
But, if neutral earth crossed, not going to learn anything new from this test. Recommend get local elektriker to check sockets. Sorry
Use a proper power lead, if you are in Germany does the socket you are plugging in to have an earth pin if not try plugging it in elsewhere with an earth and make sure the power lead has an earth as well.
Reply to PC-Case conducts energy in the UK Electrical Forum area at ElectriciansForums.net
    • Friendly
It's called Connect and Notify (the alternative being Apply to Connect).
When I was at college doing the 2361 back in the 1980's I still recall to this day the instructor (Mr Wood) saying "Lads I do not want you to...
